oil in my water
duoranger
New problem water in my oil 1994 4.3 mercruiser Im finding some water in the bottom of my boat yes I have milky oil also pudding under oil cap I had new exaust louvers put in 2 years ago also new water pump last year boat was running now running cool around 100 I cant find any water leaks I changed my oil drove it around 6 hours oil looks good all I here is cracked block or head gasket
duoranger
Water in oil
I have a 1994 searay 180 signature with a 4.3 mercruiser i have the pudding under the oil cap and water in my oil. I was told i have a cracked block or head. The boat has alittle water in the bottom of it. Can't find water leaks anywhere. I had new exhaust louvers installed two years ago. Also i had a new water pump put in last year. I changed the oil and drove about 8 hours. The oil looks good so far. Someone told me water could have got in thru the louvers. Could i be so lucky? Any suggestuions? Thank you duoranger.
a few places where water can enter the oil
the exhaust flappers
a bad engine oil cooler if you have one
cracked exhaust manifold or riser
leaking exhaust manifold to riser gasket
leaking head gasket
lots of condensation from very short runs
duoranger
I cant find any leaks I wipe up the water in the boat its not rain but after a 30 minute ride its alittle wet
if you have water in the bilge after running for a bit, time to get in the bilge with flashlights, cell phone cameras and mirrors to find the leak
duoranger
Well I found the water lesk its at the drive shaft now I wonder how much it will cost to see why there is water in my oil searay says $110.00 dollars a hour for labor would it be cheaper to buy a rebuilt motor and outdrive and be done with it what are your thoughts
duoranger
Well just got a rebuilt motor put in it was a a long block we did dry start to make sure it ran then put the motor in the boat no water was used do I need to winterize it
Ayuh,.... If the coolin' passages are Dry, it is already winterized,....
