I have a 2001 Cruisers 3075 Express with twin Mercruiser 5.7L engines, Thunderbolt IV, Bravo III drives. Just replaced one of the two motors at the beginning of the season with a long block GM OEM Marine crate engine. It ran fine on an engine stand prior to the install. The other motor was replaced last year. For reference purposes original engine SN from one of the original motors was OL358841.
Since launching this year the stbd (new) motor has been intermittently dropping RPMs and does this much more frequently at higher RPMs. It appears that the ignition system shuts off for a split second and then the engine recovers, runs great, then randomly does it again. The engine never dies, just stutters. A test light on the negative side of the coil goes out when the RPM drop occurs. So far I've replaced the ignition sensor in the distributor, swapped the ignition module/knock sensor from the other engine, eliminated the boat wiring at the cannon connector with a knock out box, supplied positive directly from the battery to the positive coil terminal and positive supply to the ignition module, replaced the coil, replaced the cap and rotor, and installed new grounds with no change. Down to it being a short somewhere in the engine wiring harness.
Does anyone else have any suggestions? I have an important trip tomorrow that I've been planning for months and after a whole week of working on this I haven't gained any ground.
Thanks,
Matthew Edson
Thanks,
Matthew Edson
