2007 496 HO Mag it has the small power steering pump that I had to replace last season. When I installed it had a small leak around the line coming in that I just could not stop from leaking. It was end of the year so I left it until this year. I worked on it again today but can just not stop the leak. Its the small pump. There's a fitting that goes on top. Its a screw in fitting with 2 O-rings. I replaced both. Then the double flair line goes into that. I put O-rings on both sides of the flair and it still leaks. I'm lost............
