PensacolaJason
- Oct 23, 2011
- 176
I just recently rebuilt my carbs with new gaskets and such and now I am having an issue with it hesitating when trying to give it gas. It idles just fine. When I pulled off the motor cowl there was a puddle of gas in front beneath the carbs. And I found that quite a bit of gas is dripping out of the hole in the front (see attached picture). I made sure that the floats were set correctly by the manual, so I'm not sure what would cause gas to drip out of these holes. When I trim the motor up the gas just pours out of each hole.
