smokincrow
- Aug 7, 2013
- 2
Hello folks, i had the replace the ignition switch on my 1976 power pilot. when i took it apart there is a detent spring and ball bearing that came out.It seems to kinda lock the throttle in forward, neutral, or reverse. I replaced the ignition switch but cant figure out how to get the spring and ball back in place. Any advice would be much appreciated. THANKS
