I have a 1981 J50belcic. Engine runs smooth at idle and no load. then bogs down at WOT especially under load.
The engine sat for 7 years, Had a mechanic give it a once over before i put it in the water.
things done - New fuel pump and hoses. New spark plugs and new wiring harness rebuilt carbs
Since then have Replaced power pack and both coils (due to spark issue) I am now getting good spark.
I replaced a damaged prop. which caused problems to get worst
With old prop (15 pitch) I get 4700 RPM, and 20 - 22 mph. the throttle goes about 3/4. then bogs down, Have to pull back a little to get sweet spot;.
with new prop. I got only 4000 rpm, with same throttle issue.
This weekend, I went with 5 adults and 2 kids. Could only get 4000 RPM with old prop, and about 11 MPH. (same throttle issue) when was done, dropped all but 2 of us off, And took it out, Got the same 4500 - 4700 RPM and 21 MPH, with same throttle issue. Did not even try new prop, as it was already bogging down with just 3 of us.
I have a 1981 starcraft SS 161 I redid over the winter.
I was reading in another thread about putting a pin through high speed orafice (can't find this in book) and was wondering where this was. Also, book says to check for bent reed valve, Which I will do once the rain stops (been raining for like 2 weeks here)
any way, Was looking for help here, and possibly other ideas. Would really like to get this fixed. i understand a 50 is small. and will not do everything I want with alot of people. But I would like to at least know it is running good so I do not tear engine up,and get out of it all I can until I can afford and FIND a bigger motor.
