scimitar858
- May 16, 2012
- 39
Hi,i have a 1970 evinrude 18hp,i have been using 50:1 petrol oil ratio,but it seems to emit a lot of smoke.Is this the right ratio,any help much appreciated.Regards Phil
Make sure that you are running the correct oil.
Just "two-stroke" or "two-cycle" description is not enough.
It needs to specifically say "TWC-3" or TWC-III"
+1. 50:1 is fine, you can run a little richer if you like. Here's a great all around link for your motor.
http://www.leeroysramblings.com/johnson_E-FD_15_18hp.html
Great to have another member from across the Pond. We seem to have quite a few now. Here are some links to vids of motors similar to yours so you'll have some idea what to expect.
http://www.youtube.com/watch?v=SM5Y8FRjVyw
http://www.youtube.com/watch?v=XM_JGQn4wbE&feature=related
http://www.youtube.com/watch?v=AC0KUsfed_Q&feature=related
Keep your eye on this forum Phil,everything you will ever need to know about outboards is here.
Geoffwga1
Ask as many questions as you like. We're glad to have y'all here no matter what the other forums may say Half the fun of these vintage motors is their ingenious, rugged design and the fact that virtually anyone can fix virtually anything on them, which is also a bit of a necessity as many shops can't/won't work on older motors anyway. Besides, there's nothing better than firing up your neat little old motor in 1-2 pulls while the other guy with the big fancy +100 hp motor is left dock scratching his head when his motor won't start. I just smile and wave as I put-put into the sunset Cheers!
Hi,Many thanks for that,The reason i joined this forum was because of the helpfulness i always get from you folks over there,the forums over here can be very sarcastic,with the well if you don't know i'm not telling you attitude,not by all but by a large majority,Rather sad but that seems to be the way of things over here nowadays.Good links by the way.Kind Regards Phil
