Hi,
I'm new, I'm new to this forum and boats and outboards and I have very little idea about what I've gotten into!!
My 14 year old son decided for his birthdayhe would like a rib boat with an outboard engine after his friend took him out on one, so after a little bit of eBay action he is now the proud owner of a Zodiac rib and an Evinrude Fisherman 6HP outboard.
The problem is, the engine takes an age to start, I mean 10-15 pulls before it will fire up. Once it's running its a little juddery and will not idle, it stalls if you let the revs drop down too much but does push his rib along quite nicely once its warmed up. The model number on the plate is 62025 C 57944, after reading a bit on these forums I think it's a '72. I would love to replace the point's and plugs and give it a general service but I have no idea where to source the parts from in the UK and I want to make sure I order the correct bit's. Also, is it worth stripping it down to clean the carb and stuff?
Thanks for any help
Mike
Thanks for any help
Mike
