Re: 1954 Evinrude 7.5 hp Fleetwin
The large Hi Speed fuel mixture adjusting knob continually vibrates off its setting during operation. I've tightened the packing nut on the shaft but it still moves. Any tricks I'm not seeing ?? Otherwise the motor runs great.
Welcome to Iboats.
When is the last time the carb has been rebuilt? I ask this because the packing may be spent, and not capable of expanding enough to hold the needle.
Two options for this, you can either go with a complete carb kit, and rebuild it.
Or, since it runs fine, you can get the packing separately for the carb;
http://www.vintageoutboard.com/
Click on "Johnson Evinrude Parts" on the left. Then click on "Fuel System Repair Parts" in the center. You are looking for item # 307583K, located a scroll down.
Or..
OMC/BRP part number 307583
MAY work.
