Greetings All,
Re-awakening my old '65 is going well.
I'd like to replace the fuel lines under the case - from the connector to the fuel pump and from the pump to the carb. I'd like to buy the hose before I take things apart but I can't find details about hose size - anyone have any thoughts?
There was, what remains, some type of plastic ring (white) on the lower unit behind the prop - but I can't seem to identify it on the parts blow-up. I've taken a photo of the area on the lower end - the ring was around the groves at the end of the case where the prop-shaft comes out (see arrow). Any ideas on part name or number would be appreciated. There seems to be a problem uploading files... please see this link:
https://picasaweb.google.com/113336...key=Gv1sRgCLiEza_56bH2swE#5710922679733393906
I've got some rough spots on the outside of the lower unit - it look like it may be the results of corrosion. Any thoughts as to what to do about these?
Thanks again to you all for your help.
Wayne
Wayne
