Re: 1973 Evinrude 2hp mate
The most common cause of water intrusion is re-use of the gasket under the drain plug. Confirm that before you start fixing stuff that may not be broke.
That gasket must be replaced every time the plug is removed. It is not a washer; it is a crushable one time use gasket. Reuse it and you WILL have water intrusion.
