so i got the johnson running real good and smooth but i have another problem at low thorttle the chungs along like there nothing wrong at about half throttle a wake starts to form and you can feel the mortor pushing you but you hear the rpms rise a litle and when the do you loose the pushing of the motor and then the rpms drop a little i mean not a big diffrence and the motor starts to push again and at full trottle the same thing is happing just it does not want to push for a longer period of time so there is no plaining and it just creating a wake could it be the shaft on the motor is not long enough and when the wake is being formed the prop is coming out of the water or does it seem to be something elese this is a 62 johnson 28hp
Thanks Josh
Thanks Josh
