Welcome Guest - Sign Up today
Store Links Mobile - Shop Now
See more
See less
What does a bad water pump look like?
  • What does a bad water pump look like?
    Hi Forum,
    A buddy and I are trying to revive a '78 Johnson 115HP. We started by reading BoatBuoy's fantastic sticky on awakening a sleeping outboard. It's been really helpful. We've taken it slow, solving electrical problems and some stubborn cylinders and now we are on to the water pump. This engine has been in storage since 82 and probably only saw a handful of hours since it was bought new in 78. I took off the lower unit (which had a good amount of sand imported from the Keys) and opened up the water pump. To my surprise, the impeller looks good as new. It's still pliable with no cracking or dried up bits There are no signs of wear or rubbing inside the pump.
    Question is: What am I looking for? Is this impeller good to go or should I just replace it on principle? I already bought a new impeller based on the assumption that the 30 year old one would be trash. It was about $50. I would love to apply this to some other needed parts if I can. Thanks for any expert input.
    Re: What does a bad water pump look like?
    change it any way. 30 year old rubber will come flying apart at 4500 rpms, remember that is attact to the drive shaft and turns the same rpms as the motor. while you have the lower off flush the water tube.
    they should be change every 2-3 three years,
    FLORIDA GATORS
    TEBOW Country
    Please, NO PM's (Private Messages) regarding boat/engine problems. they will not be answered.
    That is what these forums are for. Post your questions, in the appropriate Forum.
    • #3
      Not an expert, but answer this question: How hard was it to drop the lower unit? Would it be worth the $50 to drop it again after only one time on the water? Just my thoughts.........
      ><(((ļ>
      "I think it's time I move on like a rolling stone
      'cause I've got all the broken dreams I can buy
      Time to sell the ones I stole"
      (Poison)
      • #4
        Agree with TD 100%. Change the impeller.
        Check this link out for a really good reason,
        http://forums.iboats.com/showthread.php?t=400771
        sigpicMarada 2100 Executive Series, 5 Litre V8 with Mercruiser Alpha 1 outdrive. 2007 K-Z Spree 260 RBH, all = a whole lot of family fun !!!!
        • #5
          Change the impeller. I learned the hard way, not changing my on a motor bought used that sat up for a few years. It cost me $800 due to an engine overhaul caused by impeller that came apart, burning up the engine.
          Carl
          Carolina Skiff 175 Sea Chaser, 90hp Yamaha 2-stroke
          River City Marine 14' AL flat-bottom, 40hp Force 2-stroke
          • #6
            Thanks, Everyone.
            I went ahead and did the impeller replacement. Glad to have the good advice.
            Back to Top
