quatro4444
- Aug 7, 2009
- 24
having an issue with my 40 hp johnson, is my first boat. boat will start up fine just replaced the plugs, gas line and primer ball and fuel filter.. but if i let it run in neutral or in gear for a bit it will turn off after a while like its running out of gas.... if i keep priming the ball it will run until i stop. i have no idea what the problem is. the guy i bought it from said the fuel pump was changed but who knows couldve bullsh*tted me as well. if anyone has had this problem or knows a way to fix this please let me know and you will be my new best freind hahaha jk but really its driving me nuts since guy told me i wont have any issues at all. it started right up for me when i looked at it even drove it for 15 mins but now this.. hope someone can help. could it be the gas tank? i ran the hose directly in the tank without the clip on and it did the same thing so i dunno. any help or suggestions will be greatly appreciated.
