I understand the procedure for shift linkage adjustment. My problem is with motor in neutral and shift control in neutral linkage will not adjust out far enough to connect. with linkage connected motor will shift into forward gear but want go into reverse.. goes just far enough to get clicking of gears..thank you for any help.
