Re: Honda BF130 25" shaft back to 20" ?
The extension piece is easily removed when dropping the lower end, BUT there will be a 5" gap when you reassemble it. To answer your question, the only way you can change it to a 20" is to replace the entire lower unit with a 20" one or disassemble the lower unit and replace just the vertical drive shaft.
Good luck.
