pecheux
- Jun 9, 2006
- 1,200
Good day,
Air hose connector type gas connector on Force motor started to leak at times I suspect it sucks air which probably cause occasional engine stop when idling. I presume due to trolling speed shaking. Prior to ordering original replacement part I would like to know if Merculy type connector would fit ? The outside part is not a problem, but I dont know if there is enough room inside the cowling for the Mercury inner connector part.
Original Force air hose type is very short inside the cowling.
Thank you all.
Thank you all.
