Re: Chrysler 3.6 fuel mixture
May have gotten the Tecumseh part wrong--the mind is the second thing to go--but lawn boy made a 2 cycle mower that used the same engine--even exhausted down into the shroud. Also back in the '70s or maybe '80s someone made an "air mower" with the same engine. Mower had no wheels--blades generated enough lift to float it several inches above the ground. So, engine needed to be light--two cycle. Used to be advertised as effortless mowing and easier on hills. Never was successful though. I can imagine why. They all used the same air cooled engine--may have been slightly different bore and stroke and horsepower but I'll bet dollars that they all outsourced engines from the same manufacturer and adapted them to their own purposes.
