BonairII
- Jun 7, 2011
- 2,727
I have a Humminbird 570DI fishfinder. Currently the transducer is mounted on the transom....and the display is on the bow. I want to add a trolling motor mounted transducer. I'll be using the transom transducer when the boat is underway...and the bow mount transducer when fishing.
An extra down imaging transducer is around $159 bucks and a transducer switch is $89! crazy prices IMO.
Is there a cheaper option(universal transducer maybe?) that will work with my Humminbird? And a cheaper switch than the $89 Humminbird switch?
The transom mount transducer is only going to be used to keep track of water depth(keeping propeller safe).
Worse case....I'll just buy/use a cheapo fishfinder and use it for the transom depth readings, and use the 570 at the front of the boat.
