greenbm
- Dec 6, 2013
- 54
This is my first time posting a question but I have been reading the boards a lot and have been help a lot by reading other peoples' posts. My stern light has not worked since I bought the boat last summer. I tried the obvious simple solution first and changed the bulb. No luck. So Tonight I tried to diagnose the problem and what I've found has left me confused. Here is what I did/found:
1. Put multimeter to the contacts in the bulb socket and got a 12V reading. BUT I noticed this was when my switch was in the off position. At least I think it's off. It's a rocker switch labled Nav/ANC and the middle position seems like it means off since neither of the lights on the switch come on when in this position. Am I correct in thinking this?
2 with the switch in bothe of the "on" positions I got no reading on the multimeter
3 when I put the test light on the negative battery terminal and touch EITHER of the contacts in the light post socket the test light cm on. When I reverse and clip the test light to positive it won't come on regardless of which contact I touch
I'm wondering if the problem is in the switch or maybe how the stern light is wired to the switch. I may be leaving out important information so if I am, please ask and I will try to answer. Thanks in advance for your help. Like I said, I've learned. Lot from you guys already.
