Bigreddon
- Nov 21, 2014
- 128
I read this on another page...
"For your deck you can use the 1.5 CSM on both sides and you will probably be just fine. Some folks on here recommend a light weight cloth instead. The cloth will leave a smoother finish. If your boat is fiberglass then you will need to tab the deck to the hull with something more substansive like 1708 biaxial cloth. I used 1708 tabbing first and then completely covered the top of my deck with 2 oz CSM. If your boat is a tinny then you can skip the tabbing part." -end quote
I have a very good bed and filled edges from the deck to the hull. This person said of I have "a tiny boat" the tabbing can be skipped. When I removed the floor and was grinding te old epoxy away, I am pretty sure it was all epoxy, with no tabbing. So last question...can I skip the tabbing? My floor is hella solid, and I will have one more layer of glass onto the hull when I cover the floor.
Will this be sufficient? Keeping costs down is fine in my book, and I'm
Not racing the thing or going onto the ocean. Lake cruiser only. I know it won't hurt with the tabbing, but if it isn't absolutely necessary....
