Welcome Guest - Sign Up today
Store Links Mobile - Shop Now
No announcement yet.
Epoxy filler over primer?
  • Epoxy filler over primer?
    I have a couple of tiny areas that I want to fill after I finished my first coat of primer. About 5 tiny "dimples" smaller than a match head. Is there any reason I can't fill these directly over the primer? I am going to do a whole 'nuther primer coat, so I am not worried about paint adhesion, and these are so small and not structural, so I wouldn't die if they weren't as sound as the remaining 99.9999999999% of the surface.
    Torque gets you there. Horsepower gets you there in time for dinner.
    Re: Epoxy filler over primer?
    dont know about this one qc.....
    so im gonna watch and do some searching for ya....exactally what kind if filler are you going to use......might help...
    and....uh......why not sand the primer out of such small spots first???
    and re prime?......
    or are ya just gonna do the "shortcut method"....
    cheers
    oops
    The Hull Extension Thread
    great info on all aspects on boat building with detailed information.
    http://forums.iboats.com/showthread.php?t=234392
    IN MEMORY OF Our friend SpinnerBait_Nut LESTER WRIGHT July 31, 1953 - Nov 26, 2008 RIP
    IN MEMORY OF Our friend Tashasdaddy Robert (bob) Griffis. October 27, 1948
    November 29 2010 RIP
    • #3
      and re prime?......
      Straight Epoxy like I used on the bottom etc. Typical boatbuilding, repair, adhesive epoxy. I've got gallons of it. It is what the primer is on top of . . . I am sanding out a little, just wondered more about the areas I sand after I fill that will have some epoxy on top of primer when feathered in.
      • #4
        i dont think it could hurt.....
        but ill do some searching........
        im going to be on a road trip this weekend but ill have time at the hotel......
        try boatdesigns.net....then search the materials list....
        i wanna swipe that list and post it here but that might not be the right thing to do.....it tells you everything....but that would be stealing.
        • #5
          On car bodies many of those fillers can be added after you score up the primer so some metal is exposed for filler to adhere to. I think you could do the same thing with your boat then just feather edge it and hit with your second coat of primer.
          • #6
            Thanks, just did that . . .
            • #7
              You would be better off cutting off the primer, get down to the wood and fill with a fairing compound made for the surface.Seem's trival but you want little if any fresh glass near your finsih coat aka blushing..Are you using Interlux??
              Stickly a opinion your mileage may vary.
              Horsepower is how quickly you can get to the wall
              Torque is how far you move the wall"
              Back to Top
