Great info and ideas guys, Thanks!! Here's what I am working on now, prepping my custom aluminum belly fuel tank. Using 5200 sealant to attach the rubber type material they supplied. Was told to cut the 2" W X 36" L strips in 4" lengths and space them every 10 to 12" along the bottom, V shaped side, and sides. When it's cured I will install the tank back in the boat and have a couple cross members rewelded back in over the tank which helps the strapping down portion. My question is then; The ground tab on the tank do I run a wire from there directly to the battery for proper ground. My fill cap is all plastic on the gunnel and is secured with four ss metal screws. Sorry for the long story.... But the help I get from the forum is super, again thanks and Happy New Year!!
