super_dork
- Apr 10, 2011
- 68
EDIT 11/16/2015 - I have fixed all the photos so they are all embedded in the site now and not referencing Photobucket.
I've been keeping a progress thread over at another forum, but I've been getting lots of good info from iBoats so I thought I'd post my progress over here and see if anyone has any insight or pointers as I go along. At this stage, I've cut the back cap off and done most of the tear down work and just started the first fiberglass work last night. These initial posts are from the other thread and I'll update more as I go along.
I bought a used 19' 1993 Stratos 280 SF with a 1993 Johnson 150 in July.
It was my first fiberglass boat and I have been learning some lessons. Lesson # 1 is, always get an expert opinion when you aren't sure. I had noticed some stress cracks in the transom when I was buying the boat, but didn't think it was a big deal. Later I went to the mechanic who had serviced the boat and he asked me if the seller told me about the bad transom. I was pissed. I knew the price was too good to be true. Anyway, that's water under the bridge. Fast forward a few months. I've replaced the powerpack and rebuilt the carbs, replaced the livewell valves and cables, upgraded the trolling motor to a 24v model and taken the family out a few times (cautiously).
After lots of research, I decided that I want to do a full "cap off" rebuild on the transom. I've never done fiberglass or any real boat maintenance but I've been reading and watching how-to's and I'm ready to get rolling. I've got 2 small kids, so most of my work will be after work for a few hours.
My first challenge was removing the motor. I decided to buy a shop crane/hoist to get it off. I picked up a 1-ton unit from Harbor Freight on sale with a 20% off coupon. It only took all night to get it together. Next, I pulled the motor, which wasn't too bad. Since I will need the crane for the cap removal, needed to get the motor off of the crane so I built a motor stand out of a bunch of spare wood I had laying around. After a couple hours, I threw in the towel on using the stand and picked up an engine stand from Harbor Freight the next day. That still didn't go so well. I ended up lay the motor on the ground, raise the crane up on boards enough to clear the engine stand, then pick the motor back up and mount it.
After removing the motor, I was astonished at how bad the transom really was. I cut a small strip of the cap off to see inside and it made my heart sink. I couldn't believe that someone would sell a boat in this bad of shape and that I could have had my family on it when the motor flew off. Anyway, good thing I listened to some of you guys and decided to rebuild it. So that's where I am at this point. I will be unhooking everything and removing as much stuff from the boat as I can. I plan to remove the carpet to make it easier to find attachment points. Per Stratos support, I know that the floor is glued to the hull and bulkheads, so I'm still not sure how much access I will have underneath to cut everything free without actually cutting the floor up.
Anyway, I wanted to get this thread going and will post more as I make progress. I'm certainly open to any suggestions or comments.
