ScottinAZ
- Jun 25, 2009
- 710
Engine is a 1980 "ish" vintage Mercruiser 120 S/N 5612859. During testing for re-commissioning, I am running on hose water hooked direct to the inlet hose (no drive installed). Engine runs good, but am getting milkshake in the crankcase, and when I pulled the plugs this morning, and cranked it over, I got Old Faithful from all four bores. To my knowledge and understanding, that does NOT indicate a cracked head or cylinder, as that would only affect one cylinder. I am thinking the manifold may have packed in, but do not know the condition of the gasket going to the "riser/elbow/thingamagig" that connects to the manifold. No sense in "pressure testing" as it leaks on straight free flowing hose pressure. What would be the likely failure points for these symptoms. Right now I gotta go WD-40 the bores to keep them from rusting up......
I DO NOT KNOW the full prior history of the boat or motor. I bought it this summer as a project, and it has not been registered and on the water since 2014. This is Arizona, so we dont typically get hard freezes that would compromise the block (it can happen, but its rare). I bought the boat out of Tucson, so it gets hot, but not "cold".
