FiBerOpTiK
- May 26, 2017
- 24
I am in the process of rebuilding my 1984 Johnson 9.9. I completely tore the powerhead down and installed new piston rings, honed the cylinder, and reassembled using assembly lube and all new gaskets and seals. I had to replace one of the pistons due to a piece of metal chipped off the piston around the ring. Cylinder had no scoring at all, I got lucky.
I have gotten the powerhead reinstalled on the midsection and got the starter, stator/magneto assembly and flywheel back on.
This thing is really hard to turn over. I can barely turn it with one hand with plugs removed by turning the flywheel, but not easily. I threw a compression tester on it and only get around 40 PSI with both the electric start and trying to pull it with the rope. Keep in mind this thing is not turning over very quickly at all, which is why I think the compression is low. I cant hold my finger over the spark plug hole while turning it over, it will push my finger off.
I thought the battery was just dead at first, but charged it up and getting same result. It will turn it over a few times pretty quickly then just slows way down to like one revolution every couple seconds.
Is this normal for a complete rebuild or is something wrong?
What should I check? I hate to pull this thing completely back apart, but I will if something is wrong. Any help would be appreciated.
