Anyone know that proper float leavel on these things, and how can they be adjusted?
S Snap43nib Seaman Apprentice Joined Jan 18, 2010 Messages 48 May 13, 2010 #1 Anyone know that proper float leavel on these things, and how can they be adjusted?
TOHATSU GURU Admiral Joined Jul 22, 2004 Messages 6,164 May 13, 2010 #2 Re: 92' NS90A float question It should be level when you flip the carb.
S Snap43nib Seaman Apprentice Joined Jan 18, 2010 Messages 48 May 13, 2010 #3 Re: 92' NS90A float question how can they be adjusted???
TOHATSU GURU Admiral Joined Jul 22, 2004 Messages 6,164 May 13, 2010 #4 Re: 92' NS90A float question You would bend the plastic tab if they needed to be adjusted...Which they almost never do. If it isn't level, it is much more likely that the needle is worn and needs to be replaced.
S Snap43nib Seaman Apprentice Joined Jan 18, 2010 Messages 48 May 13, 2010 #5 Re: 92' NS90A float question one float is level the other 2 are the opposite way than if the needles were worn? I guess I will try to adjust them tonite, Thanx
