I have a 65Hp 1972 Evinrude model#65273. Last season she ran great in the begining. End of season it would start right up and idle fine. When I increased the throttle to WOT the engine would bog down and boat would not move faster than idle speed. Checked compression got 110 - 120psi on all 3 cylinders. Replaced plugs new champion L77J4 gapped at .040. No air leaks in fuel bulb and lines all replaced prior to last season. Fuel pump is only 3 seasons old and is leak free. When troubleshotting I found my ignition coils were cracked. I read on another post in here that that might be the problem. All three coils were replaced. I took it down to the water to test it this weekend and it still bogs. I looked in side the front of the plastic plugs on the carbs while it was running I can see the fuel misting into the openings. I am not sure it is the carbs. Could it be the power pack or am I wrong on my assumption of the carbs? If it could be the power pack is there a way to test it without the Evinrude neon tester? - sorry for the long post. Thanks
