Hello all, I have a couple questions about my 4 stroke tohatsu and why it wont run properly
1) When I prime the fuel to the engine, it doesn't feel like its going to the engine because the primer bulb wont tighten (this one baffles me because I have tried multiple portable tanks AND fuel lines, bulbs)
2) After I do finally get fuel to it, I can start it, warm it up in idle and after about 3-4 mins of 1/2 to full throttle, it all of a sudden shuts off. I have found that while underway if I continue to pump the primer bulb, then the engine runs fine.....
To address what I have checked the following:
1) i have connected the engine to multiple tankes and lines to see if the issue was outside of the engine.
2) Taken off/apart the carb and thoroughly cleaned
3) replaced the fuel filter and inspected fuel lines.
I've reached my knowledge of these things and how to diagnose and remedy. I'm wondering if its a fuel pump issue??
