harleyman1975
Ensign
- May 12, 2003
- 959
At the lake this past weekend another guys boat was having issues. First problem was alarm beeping twice Beep Beep approx. every minute. Second problem was it would die if shifted into gear (it would die sometimes in neutral too come to think of it). Third problem and possibly related to first problem it would overheat when he was finally able to get it to stay running in gear and try to get on plane. Things I noticed looking at it from the dock 1. there was a ground wire (12-14 gauge with eye) just loose. I suggested that it be attached to a ground but they said "no it has always been loose", second I said that the water pump is suspect and recommended changing it, 3rd I recommended they not keep trying to run it with it overheating as it would burn up exhaust shutters. I was told that it had new cables installed. I suggested that they may be adjusted improperly causing it to die. Saw the boat pulled and their plan is to bring back to servicing dealer I think. Funny how everything seemed to happen all at once. He was wondering if beeping was related to it not staying running?
