Hi. Loosen the pressure release vent screw so you can manually lift and lower the engine by hand. As you move the engine the whole assembly moves towards and away and swivels. Probably much easier to take the whole thing off. Pump and all. Knock the rod out one end and remove, but it defo moves to only just allow access to the bolts if patience is on your side.
