Todesengel
- Jul 18, 2005
- 22
Hey guys,
I am trading one of my saltwater aquariums for a 1981 invader vee 16 with a 85hp Johnson on it, and I don't know much about this motor and I was curious what you guys could tell me about it? The owner of the boat had the battery disconnected, and when he fired it up for us he only hooked up two wires and left about 6 others not hooked up. The boat fired up fine and ran great, it pee'd out of two holes near the rear of the lower unit. It was a steady stream for about 3 inches on both sides.
The control panel had this buzzer alarm going off in it every time we turned the key into the on position. Is this the overheat alarm? Could it be because he didn't hook up all the wires to the battery? We only had it running for 4 or 5 minutes, so I don't think it could of overheated, and It was peeing... The guy said he has never heard it before.
Are these reliable motors? Anything I should be extra careful with? All the moving parts on the motor were lubed, and the motor was very clean. And it idled no problem, unfortunately I don't have the resources for a compression test.
Thanks,
~Josh
edit:
After looking at a video on youtube, it looks like it's suppose to pee out of the side of the motor, not the midsection. I am going to have to double check.
Thanks,
~Josh
edit:
