BWR1953
- Jan 23, 2009
- 5,906
I'm in "search mode" for a used 2-stroke 150-175HP Mercury, possibly 2, but just one at a time. I choose Mercury partly because I'm a fan, but also because the only repair shop in my area is for Mercury. Logistics is a factor for me.
I've been doing a broad search, a ton of reading and watching videos online. I'd get fired up about one year-group, then read that those were not good. Or some such. My local Mercury repair shop steered me away from a few as well. I definitely don't want anything from the 70s or early 80s. That puts me in the range of mid-80s up to about 2007.
One thing that I do in my research is to check parts availability, either aftermarket or OEM for a motor I find interesting. That can be a major factor. I was seriously revved up for a Merc XR4, only to find that a voltage regulator is $800! That was a bummer. From what I'd read, the XR4 was designed for bass boats (music to my ears!) and actually had an output of 170-180HP. Glorious!
I'd been interested in the 1990 year(s) EFI versions, but my repair guy said to steer clear because of electronics failures and parts availability.
And another factor for me is saltwater. I'm a bass angler, so don't go into the briny deep. This being Florida, there are loads of engines which are used in saltwater and owners always advertise them as "flushed and washed" after every trip. Uh huh.
Any suggestions on which engines may be best? Things to watch out for? Would an XR6 work? I've read that it's rated closer to 170HP as well
All help appreciated.
