Slow to no cranking at times
Laneman25
5.0 GL Cranks slow at times, sometimes it's fine. All cables in engine area clean and tight. Battery at 12.8, 14 volts while running. Ignition switch? Starter? Solenoid? How do I narrow it down?
pull the plugs, does water shoot out the plug holes?
did you clean all the battery cable connections with 150 grit sand paper?
Laneman25
I cleaned the pos terminal cause it had some green powder starting. Neg looked good on outside but I didn't clean it.
bruceb58
While cranking, measure voltage drop in the negative cable followed by the positive cable.
Measure the voltage of the battery to see what it drops to while cranking. The voltage should be lower than between 9.6V and 10.0V.
