will i have to switch the trigger wires to the two cdi wires not used on the rear cdi , i think is green/white and redYes, use the lead that works and/or the one that normally would hook to Coil#4 (if applicable)
I'm not sure what you mean; follow the schematicthank you that is exactly what i have right now . my cdi electronics stator instruction says in a little box on top of the diagram that the new stator design allows for "all blue and yellow wires to be hooked up together" i didn't install that way because i wasnt sure, should i try it that way ?
yes the Trigger-wires from #3 to input #4 CDI AND the wires coming out of the CDI that would fire #4 to coil#3will i have to switch the trigger wires to the two cdi wires not used on the rear cdi , i think is green/white and red
i started hooking it up but im stuck on the trigger wires im not sure if they need to be specific or not .i have a grn and white striped and a red from cdi and a orang and green from trigger will i damage anything if the trigger wires go in reversedyes the Trigger-wires from #3 to input #4 CDI AND the wires coming out of the CDI that would fire #4 to coil#3
YES, you need to be specific! below is the wiring set-up of a 4 Cyl. if that helps?i started hooking it up but im stuck on the trigger wires im not sure if they need to be specific or not .i have a grn and white striped and a red from cdi and a orang and green from trigger will i damage anything if the trigger wires go in reversed
thank you Mr Force Power i just got it going good all 3 are firing and its starting within a half of a flywheel rotation im so happy ill get to actually take this boat out of the bay this year thank you and everyone else for the help this forum is awesome.YES, you need to be specific! below is the wiring set-up of a 4 Cyl. if that helps?
I'm glad you're got it going & for letting us know!thank you Mr Force Power i just got it going good all 3 are firing and its starting within a half of a flywheel rotation im so happy ill get to actually take this boat out of the bay this year thank you and everyone else for the help this forum is awesome.
