Re: NGK vs Champion plugs/ hard to start fixed
The brand of spark plug can definitely make a difference. Years ago I was driving a Mercury Grand Marquis with a 5.0L engine. I had bought the car with a motor problem, swapped in a used engine which haunted me with a slight miss for years. It had gotten a fresh tune up from the point of install along with any other maintenance items due at that time. The new to me motor had only 11,550 miles on it. I had driven the donor car home and it ran fine. I had never driven the Mercury until the motor was changed.
I had installed 8 new Bosch platinum plugs, thinking that I was prolonging the next tune up. I chased the running problem, which was minor but annoying, for years. Time came for a tune up, I installed a set of Autolite platinum plugs this time. The miss got so bad it wasn't drivable. Not at all thinking it was a plug problem went through every sort of diag test in the book, but found nothing. It felt more like a lean miss than anything else.
I let the car sit for a year or more since I had been given a new company car. After leaving that job, I went about reviving the old Mercury till a new car arrived, I found that some critters had eated the plug wires, so again, it got new plugs and wires. This time, the only source I found for parts was the dealer, so in went brand new Motorcraft plugs and wires. I didn't drive the car much at first, but soon realized that the miss was gone. The car ran better than it ever did. The only different change was the Motorcraft plugs, which this time were not platinum either. I ran that car for another 7 years with no problems till finally selling it last year, still with that last set of plugs.
I had a similar issue with a set of Autolite plugs in my truck, which at the time, I couldn't find OEM Motorcraft plugs for, it ran just plain bad with the new Autolite plugs, so bad that I finally put the old plugs back in and ordered the OEM spec Motorcraft plugs. Up until that point, I had always figured that the Autolite and Motorcraft plugs were one in the same but apparently that's no longer the case.
What I noticed was that in that case, if I cross refferenced the OEM plug number to Autolite, it gave me the Autolite number I had used, but if I cross referenced the Autolite number through the Motorcraft catalog, I got a different plug number. I found this with several brands.
I have mostly all Johnson/Evinrude motors, they all run Champion plugs with the exception of one 15hp that for whatever reason likes NGK plugs, it had a set in it when I got it, I tried a set of OEM plugs but it didn't run or start as well. I went back to the NGK plugs. I do believe it's got a pair of aftermarket coils on it too.
