The '58 18hp wants to start so bad she can taste it.
I've read posts that got me through the coil, points, carb kit, fuel lines. I think I'm ready to here her run. Yesterday I tore the gas tank apart and installed new gaskets.
Today I only put 1 gallon of oil/gas in the tank because after it starts and shows me she is going to, I want to add the seafoam and perform the
de-carb.
I set it up in a test tank but I can't get fuel through the lines. I should see it in the filter bowl. Nothing. I won't light off. I know I have good spark.
I sprayed pre-mixed gas in the spark plug holes and when I pulled the cord. She cranked right up....until that was burnt up, so 2 seconds.
Question: After a carb clean and replacing the fuel lines etc, how does gas get through all the lines and bowls? By pressurizing the tank?
de-carb.
