Re: Yamaha 225 Four Strokes
find another dealer<br /> that one is full o stuff like a xmas turkey.<br /> there is a tech bulliten out that addresses stalling after prolonged trolling and idling. it is a case by case repair not a recall. you guys in the sunny south will see more than us.if you take the elements out just remember the low pressure pump is almost 200 and the high pressure almost 600 and the removal of the filter will void any warrenty. trash in the VST is not a warrentable problem. any dealer that will tell you to remove filters and such I would be wary of. yammy put them there for a reason.<br /> if you have a hull problem then fix that but the engines are well tested and have no filter problems. like I say there is a bulliten that covers stalling with the F200,F225. its long and involved and some techs are having some problems installing it so they do jiggy things.<br /> good luck and keep posting
