Re: Winterizing
My manual also recomends pulling petcocks and draining....then it also says (if you want to be sure) to <br />a) remove t-stat<br />b)remove hose from end cap manifold<br />c)pour antifreeze solution in t-stat hole till head and block are full<br />d)pour anti-freeze sol. in front manifold cap till manifold is full (kinda important...when I got my boat the manifold was cracked)<br />e) reinstall t-stat and manifold en cap hose<br /><br />(then of course change oil, stern drive lube, ect...)<br /><br />Also when using anti freeze....I use rv type non-toxic to humans, animals, fish...
