I have a Mariner 9.9 682C and have problems with it fouling the plugs when am idling for long periods of time. The lake I frequent is idle only so the motor typically only gets to hit idle speeds. I have make sure my fuel mixture is correct and last spring I rebuilt the carb, but the problem still persists. It calls for a NGK B7HS-10 plug but was thinking if I could find a hotter plug it might prevent the fouling. Is this something I should try, if so what plug? If not what else should I look at?
Thanks.
Thanks.
