The iboats forum moderators are excited to announce that at this time it appears the iboats forums posting pictures function is working once again. Though we cannot promise for how long, we're hoping for indefinitely.
Ah, well that makes a whole lot more sense. Thanks very much for the heads up.
So, along with this kit, I would also need some synthetic gear lube and a pump. Anything else for a simple impeller change? Is 1 quart of gear lube enough?
The A1 G1's take just over a quart, the G2's should be similar. I use the HP synthetic, very expensive @ $16-17/qt, but only a buck or two more than the standard drive oil.
