Re: Which gas is best
Triumph makes a good point. One other item to consider is where you buy your gas. In the large metropolitan area that I live in, all gasoline - by law - is at least 10% ethanol. Some of it is 15%. Unfortunately, I suspect that some of it contains a much higher percentage of ethanol. I recently read that some retailers have been selling gas that contains as much as 48% ethanol. This is apparently because some of the less reputable fuel dealers will cut gasoline with ethanol as a means of stretching their profits. For this reason, I buy gas only at the majors - and even then only at a station that appears to be a well managed franchise. I realize I could buy it maybe $0.20 per gallon cheaper down the road, but that's a total savings of less than $5 a tank. Don't get me wrong - $5 is a nice chunk of change, but it's not worth putting dodgy gas in a boat I have already spent a small fortune on.
