Where's the fuel on the top cylinder? 1984 70hp
cmuman
I have been trying to figure out why my 70 hp outboard didn't change when I pulled the top spark plug. I thought it was originally a fuel issue, so I dove into the carburetor. It seemed that the fuel bowl was getting fuel. We took a sprayer with gas/oil and shot it into top cylinder. It seemed to speed up the engine. I took the carburetor off and cleaned the passages and checked the jets. (2 that I could find.) It appeared that I got everything clear. I put the carb back on with hopes and..... same problem.
I then persued electrical. I've got good spark and it seems that every plug is firing good when it should. I put new plugs in the motor, and the top one ended up dry after trying to run it. So...
Then I switched back to fuel. I started it up for a sec to see if squeezing the primer would change anything. No change.
All compression is at 115 on all cylinders.
I cleaned the carb, but didn't put a carb kit on it.
The engine still has no change when you pull the top plug, but pull the other 2 one at a time.
Any ideas? Thanks in advance.
Silvertip
Re: Where's the fuel on the top cylinder? 1984 70hp
You still have a fuel issue. the main jet or a passage in the carb is blocked. If the engine speeds up by giving it a shot of fuel, you found the issue. You now need to determine the cause. Unfortunately we can't see your carb so you need to ensure every passage is squeaky clean. And just so you know, continuing to run it without fuel means it also not getting oil. No oil causes bad things to happen.
JB
Many "cleaned" carbs are still plugged in the critical orifices, cmuman. The ones that open into the carb throat.
Other possibilities are a reed or a gasket leak in the intake area or bypass.
cmuman
The passage that I couldn't get as clean as I wanted was the skinny tube passage from the bowl up to the throat of the carb in front of the butterfly. Is there any tricks to get this clean? It seems that there is a small hole in this tube right next to the butterfly. I tried cleaning it out, but obviously I need to do better.
I only ran the engine long enough to check the spark and then pull the plugs. Then I figured out myproblems with the carb.
wavrider
Napa carb cleaner in the 1 gallon can, has a basket to soak the parts in.
I have tried all the chemicals, acetone, spray carb cleaner, they both do ok but the high dollar carb parts cleaner from NAPA worked the best.
you need to blow compressed air through the orfices to see if they are clear.
tashasdaddy
i remove my jets, special tool also take a a piece of stranded wire, take 2 or 3 strands, twist together , and run thry the jets, be surprised what the break loose.
cmuman
Is the skinny tube running from the bowl up past the butterfly supposed to come out? Where can I find those jet screw drivers?
tashasdaddy
they are part #317002 +-$18.00 the red/black handle ones i made from a quality screwdriver, with my belt sander, you could use a grinder also. tube, no, blow compressed air up it. or thin wire. that is the high speed pickup, from the high speed jet in the bottom of the carb.
cmuman
I found 2 jets in the top of the carb one behind a short fat screw and one behind a rather long skinny screw. Is that all of them?
When I was looking at the carb kit for my engine, it looked like it came with a gasket for some type of metering circuit. I only found a gasket on the bowl and a small circular one inside the bowl. Am I missing something, or is that gasket not part of my carb?
cmuman
The jet looked clear. I will take some twisted wires and clean them out, but how do you know that a jet needs replacement?
tashasdaddy
very rarely do they need replacing.
Willyclay
I removed and cleaned the same carb three times before I could get one of my motors to idle properly. If it doesn't run right, it is not clean. Good luck!
cmuman
Willy, was there a stubborn spot that you found that I might be able to watch for? Did you soak the carb? What finally worked?
Willyclay
My low speed/idle jet had some really hard crud in it that did not come out with soaking & spraying carb cleaner or compressed air. Finally got it out with a needle that I stole from my wife. I've found that brake parts cleaner is very effective also but it will ruin rubber or plastic parts so be careful!
cmuman
I know how potent brake cleaner is. Some fogged on my lawn tractor when my buddy was working in my garage. No fun
cmuman
Which one is the low speed jet? the one in the center above the throat opening or the one off to the side by the vacuum line??
guy74
Number 27 is the idle jet. I'm not sure what #22 does, maybe it is a midrange fuel orfice. Am I right in assuming that the top cylinder isn't getting fuel at idle, or at least not enough to run on? If that is the case, your problem must be in the idle ciruit, if the float bowl is full of fuel. Make sure you get the #27 jet and the fuel passages going to it clean.
Goodluck,
Brian
