4.3L LX merc with balancer shaft. 1997 hull.
Had strange popping and flames out of carb when i went to advance just past idle so i thought it could use a tune up.
started doing tune up when i saw rusty plugs and water in cylinders. Turns out to be bad manifolds. I still had those one piece ones that merc doesn't even make any more.
So i got the new manifold kit, sent the heads out to be inspected, got everything i needed and put it back together. Did an oil change before starting engine. started it up and......same exact popping noise with flames when i go to rev it up slowly past idle. It did run good at full throttle before i did this work but i haven't checked it out now. and i did finish the tune up with cap rotor plugs and wires.
To diagnose this popping i checked timing which is fine and i have a timing light that i can advance and the timing did advance. (I don't know if that tells me if the timing will advance without the light though). thought about bad valves but they were checked when the heads were sent out. i thought about bad lifters but with the rocker arm cover off and cranking engine i can see the valves going up and down without question.
i did see in the carburater what looked likes droplets all over the butterflies but i can't tell if it is fuel or water. i dont know if fuel collects like that on the butterflies.
the other thing i saw is that the oil is still milky after the oil change but i did put in a full 5 quarts and plan on doing another oil change but i don't think that will cause this popping. it sounds more electrical to me
