I have a 1985 Force 85 Horsepower motor. I just replaced the water pump but am getting zero flow from the two "pee holes". I am using a water tank ( i.e. a rubbermaid storage bin) I used a pump kit without a new housing. The housing had some corrosion on the inside and I sanded it with some fine grit sandpaper to smooth it out. The impeller seemed to make proper contact. I also changed the seal on the driveshaft. I do think I aligned the water inlet properly. If I blow through the "pee hole", ( insert random joke here)<br />I can hear it come out from the trim area. I am not letting it run longer than 15 seconds at a time so I do not damage the impeller.<br /><br />Any ideas here? I am new at this. I would appreciate any input.<br /><br />Thanks,<br />Rob the newbie
