i have got a remanufactured block that is getting water in cylinders 2 and 4.
last year i put it in because it got water in it from bad manifolds and risers. so i got new of those and new block.
what happens is i can get to about 3600 rpms only and that is how i first noticed the problem.
i pull the plugs and crank the engine and it comes out a lot on number two and a little on number four. I can keep my finger over the hole with a rag and it starts to get less and less coming out but if i let it sit for a bit then turn it over a lot comes out of number two and i go through the same process of putting my finger over the whole with a rag. then if it sits again more will once again come out.
i at first thought it was from that side of the engine being too low to the water line so i raised the riser and it is now 16" above the water line and doing the same thing.
my guess is a bad head gasket but i can't imagine why after such a short time of using it.
also, when i pulled off the riser to add in a spacer i looked in the manifold and there was pools of water in there. (i did drain both the manifold and block before pulling off the riser).
