dozerII
- Oct 25, 2009
- 6,527
Hello all been a while since I posted in this section. I have a 79 Evinrude 85hp model 84999R. The gasket between the water pasage cover and the head on the port side was leaking just below the lower spark plug quite badly. When I removed the cover three bolts broke in the head and are impossible to get out so I found a used head on Fleabay which is in the mail. This morining I was cleaning everything up and on the block I found a approximatly 2"long peice of small rubber tubing jammed in bellow and to the right of the lower cylinder. There is another one that looks like it is where it is supposed to be, between the two cylinders slightly off to the port side. Would this have caused overheating problems or other problem?
Glen
Glen
