Guys,
I have a 2000 Volvo 5.0 GL engine and I need to do some maintenance. I need to start with changing the oil. Can someone suggest a web site that would tell me the engine oil filter part number as well as the suggested oil weight to use.
Also I haven't had the out drive serviced in 3 years. I keep reading about bellows needing to be changed and I'm not even sure what these are. I've been adding grease to the one site on the side of the outdrive but that's all I've done. I store the boat at the marina on a lift if that matters. Also is there a good service manual for the Volvo's that would show how to remove, service, and replace the outdrive? Thanks in advance for any help and suggestions.
