vro pump
buckw3
i had my 86 johnson 70 hp to the dealer and he told me that the vro pump is leaking gas and needs to be replaced is this true should i just replace the vro pump
clanton
Re: vro pump
I have a rebuild. works great, good, price, I will have to look for the address and ph number. Same outfit that does some rebuilding of the direct injected engine.
seahorse5
Re: vro pump
dfitechnologies.com<br /><br />They carry rebuilt pump assemblies<br /><br />(there you go, Clanton, you owe me one!)
buckw3
Re: vro pump
Thanks for the quick responses i will let you know how i make out
buckw3
Re: vro pump
could not find the part on the web so i email the company hopefully i will hear back
clanton
Re: vro pump
This was the first pump from these guys I have seen or used. I am impressed. When I installed the pump, I did not prime oil line, I let the pump pickup the oil, and check the alarm at same time. I only got about 3 beeps from the alarm and the pump was pumping oil. The engine is a 70 hp, which is not know for a good idle. I now have it running so slow that you can almost count the rpms with a chalk mark on the flywheel.<br /><br />Thanks Seahorse.
buckw3
Re: vro pump
hopefully i will get this ordered i will let you know how i make out
buckw3
Re: vro pump
i talked to dfi technologies today and they are no longer selling them. they rebuild yours for the same price. pain any other ideas where i could find one
buckw3
Re: vro pump
anybody have an idea where i can get a new vro pump or the best way to fix the broken one
Re: vro pump
If you would like to try and rebuild the pump yourself, go to mastertech marine online and he has the rebuild kits available. That is a new diaphram and gaskets. You can get both sides done for oil and fuel for about 45.00.
buckw3
Re: vro pump
is this real difficult or can you handle it<br />ive done alot of atv work torn engines apart and rebuilt them can i handle this. is there any special tools you need
clanton
Re: vro pump
Send the pump to them, Thats what I did, you save money and it works great.
buckw3
Re: vro pump
SEND THE PUMP TO DFI THEY DO A GOOD JOB ITS WORTH THE MONEY?
buckw3
Re: vro pump
ordered parts to rebuild myself from mastertech marine does not appear to be too difficult have the parts hopefully sat let you know how it turns out
buckw3
Re: vro pump
RECIEVED THE PARTS QUICKLY FOR MASTERTECH HAVE NOT REBUILT IT YET MASTERTECH WAS VERY QUICK ON GETTING ME THE PARTS HIGHLY RECCOMEND THEM
buckw3
Re: vro pump
the vro pump was easy to rebuild but i am still having trouble getting the boat to run full with pushing the primer any suggestions
buckw3
Re: vro pump
the boat ran fine out of the water the minute i put it in the water it quit was starting but wouldnt go then it quit starting. i noticed when you pump the ball on the gas line it doesn't get pressurized you could hear the gas pumping somewhere around the motor couldn't see it running out anywhere ANY ideas would be greatly appreciated
trumpetbucks
Re: vro pump
No pressure on the ball sounds like you may have a pinhole in the fuel pump diaphragm, or a tiny leak somewhere in bulb/line assembly.
buckw3
Re: vro pump
hope i dont sound stupid but is there any way to check the fuel pump diaphram can i see it thanks for the help
