charleswmoore
- Oct 30, 2002
- 105
Recently went around the block identifying correct<br />Gimbal bearing and U-Joint Spiders. My drive is a 2001 manufactured in April. All the books and parts list the local marinias have show the incorrect spiders. The correct part number can be <br />found on stemtostern.com under the "b" version <br />drive specs. (Or at least I hope) After giving <br />Volvo the part number off the double center they back tracked the Spiders to the same number <br />stem to stern lists. Also the Gimbal bearing has <br />been changed to have a rubber sleave between the<br />outer race and the press sleave. <br />FYI happy boating <br />Charlie
